Ga door naar hoofdinhoud
Lenovo IdeaPad Flex 4-1470 Removing the Lower Case
Wat je nodig hebt
  1. Lenovo IdeaPad Flex 4-1470 Removing the Lower Case, Lower Case: stap 1, afbeelding 1 van 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Removing the Lower Case: stap 2, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1470 Removing the Lower Case: stap 2, afbeelding 2 van 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Demario Robinson
1.038 Reputatie
4 handleidingen geschreven
USF Tampa, Team S1-G6, Thompson Fall 2017 Lid van USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
3 Leden
10 handleidingen geschreven
Één opmerking
can someone please tell me where to find the back cover? i need to order it
angel etoile - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 73
Altijd: 19,152
