Inleiding
This guide will help you to replace your computer's motherboard, one of the most essential components of your computer. To replace this, you will have to take apart a good portion of your laptop, so be ready with sufficient tools, work area, and time.
Wat je nodig hebt
Remove the eight 6 mm screws using a Phillips #0 screwdriver.
Remove the two 11 mm screws using a Phillips #0 screwdriver.
Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
Remove the cover.
