Ga door naar hoofdinhoud
Lenovo IdeaPad Flex 4-1470 Motherboard Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: stap 3, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: stap 3, afbeelding 2 van 2
    • Remove the two 4 mm Phillips #0 screws which mount the fan.
  4. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: stap 4, afbeelding 1 van 3 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: stap 4, afbeelding 2 van 3 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Using the Precision Tweezers, remove the 2 gray wires around the fan from their clips.
  5. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: stap 5, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Use 2 plastic opening tools to remove the fans power wire from the Mother board and remove the fan.
    • Lift the cooling fan out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Wifi Card: stap 6, afbeelding 1 van 1
    • Remove the foam on the WIFI card.
  7. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the wires attached to the WIFI card.
  8. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Unscrew the 4mm screw holding wifi card.
  9. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Motherboard: stap 9, afbeelding 1 van 1
    • Unscrew the twelve 4mm screws with a #0 Phillips screwdriver.
  10. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Remove the motherboard.
    • The motherboard will be in place when the screw holes line up.
Conclusie
Elijah Ellis
616 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 Lid van UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 1,299
