Ga door naar hoofdinhoud
Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: stap 2, afbeelding 2 van 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Cooling Fan: stap 3, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Cooling Fan: stap 3, afbeelding 2 van 2
    • Remove the two 4 mm Phillips #0 screws which mount the fan.
  4. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: stap 4, afbeelding 1 van 3 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: stap 4, afbeelding 2 van 3 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Using the Precision Tweezers, remove the 2 gray wires around the fan from their clips.
  5. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: stap 5, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: stap 5, afbeelding 2 van 2
    • Use 2 plastic opening tools to remove the fans power wire from the Mother board and remove the fan.
    • Lift the cooling fan out of the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Demario Robinson
1.038 Reputatie
4 handleidingen geschreven
USF Tampa, Team S1-G6, Thompson Fall 2017 Lid van USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
3 Leden
10 handleidingen geschreven
Één opmerking
will the same fan fit to lenovo ideapad flex 5 1470 ?
Rajeshwar Choudhary - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,653
