Ga door naar hoofdinhoud
Lenovo IdeaPad Flex 4-1130 Touchpad Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Remove the ten 4mm screws from the back panel.
  2. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: stap 2, afbeelding 1 van 1
    • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Do not insert the spudger too deep! This could potentially damage a device part.
  3. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: stap 3, afbeelding 1 van 1
    • Remove the connector attaching the battery to the motherboard.
  4. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: stap 4, afbeelding 1 van 1
    • Remove the four 4mm screws on the battery.
  5. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: stap 5, afbeelding 1 van 1
    • Lift the battery with a spudger and remove.
  6. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Remove eleven 6mm screws.
  7. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: stap 7, afbeelding 1 van 1
    • Lift up black flap on the ZIF connector and pull the ribbon cable out.
  8. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: stap 8, afbeelding 1 van 1
    • Lift up on the black tab on the ZIF connector and pull the ribbon cable out.
  9. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: stap 9, afbeelding 1 van 1
    • Remove connector cable.
  10. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: stap 10, afbeelding 1 van 1
    • Remove one last connector cable.
    • Motherboard should now be completely disconnected and can be lifted off the cover to be replaced.
  11. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement, Touchpad: stap 11, afbeelding 1 van 1
    • Due to the amount of force required to remove the screws holding the touchpad, we recommend removing the motherboard before attempting this replacement to reduce the chances of damaging any components.
    • Lift up the black tab on the ZIF connector and pull the ribbon cable out.
  12. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: stap 12, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: stap 12, afbeelding 2 van 2
    • Remove three 8mm screws.
  13. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: stap 13, afbeelding 1 van 1
    • Push the touchpad outwards to remove it.
Conclusie
Adrian Miranda
677 Reputatie
5 handleidingen geschreven
USF Tampa, Team S17-G5, Boczar Spring 2018 Lid van USF Tampa, Team S17-G5, Boczar Spring 2018
USFT-BOCZAR-S18S17G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 679
