Ga door naar hoofdinhoud
Lenovo IdeaPad Flex 4-1130 Screen Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Flex 4-1130 Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Remove the ten 4mm screws from the back panel.
  2. Lenovo IdeaPad Flex 4-1130 Screen Replacement: stap 2, afbeelding 1 van 1
    • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Do not insert the spudger too deep! This could potentially damage a device part.
  3. Lenovo IdeaPad Flex 4-1130 Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove the connector attaching the battery to the motherboard.
  4. Lenovo IdeaPad Flex 4-1130 Screen Replacement: stap 4, afbeelding 1 van 1
    • Remove the four 4mm screws on the battery.
  5. Lenovo IdeaPad Flex 4-1130 Screen Replacement: stap 5, afbeelding 1 van 1
    • Lift the battery with a spudger and remove.
  6. Lenovo IdeaPad Flex 4-1130 Screen Replacement, Screen: stap 6, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1130 Screen Replacement, Screen: stap 6, afbeelding 2 van 2
    • Remove six 7mm screws.
  7. Lenovo IdeaPad Flex 4-1130 Screen Replacement: stap 7, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1130 Screen Replacement: stap 7, afbeelding 2 van 2
    • Remove two connector cables.
    • Separate the two unhinged parts.
  8. Lenovo IdeaPad Flex 4-1130 Screen Replacement: stap 8, afbeelding 1 van 1
    • Use the spudger to remove the plastic caps, uncovering the screws underneath.
    • Remove the two 6mm screws.
  9. Lenovo IdeaPad Flex 4-1130 Screen Replacement: stap 9, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1130 Screen Replacement: stap 9, afbeelding 2 van 2
    • Use the black nylon spudger to remove the long plastic covering underneath the screen.
    • Remove three 6mm screws.
  10. Lenovo IdeaPad Flex 4-1130 Screen Replacement: stap 10, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1130 Screen Replacement: stap 10, afbeelding 2 van 2
    • Use the black nylon spudger to lift and separate the screen from the plastic back cover.
  11. Lenovo IdeaPad Flex 4-1130 Screen Replacement: stap 11, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1130 Screen Replacement: stap 11, afbeelding 2 van 2
    • Peel off tape and remove the cable.
  12. Lenovo IdeaPad Flex 4-1130 Screen Replacement: stap 12, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1130 Screen Replacement: stap 12, afbeelding 2 van 2
    • Remove the connector chip.
  13. Lenovo IdeaPad Flex 4-1130 Screen Replacement: stap 13, afbeelding 1 van 2 Lenovo IdeaPad Flex 4-1130 Screen Replacement: stap 13, afbeelding 2 van 2
    • Peel tape and remove cable underneath.
Conclusie
Adrian Miranda
677 Reputatie
5 handleidingen geschreven
USF Tampa, Team S17-G5, Boczar Spring 2018 Lid van USF Tampa, Team S17-G5, Boczar Spring 2018
USFT-BOCZAR-S18S17G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,716
