Ga door naar hoofdinhoud
Lenovo IdeaPad A1-07 Motherboard Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad A1-07 Motherboard Replacement, Back Cover/Midframe: stap 1, afbeelding 1 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement, Back Cover/Midframe: stap 1, afbeelding 2 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement, Back Cover/Midframe: stap 1, afbeelding 3 van 3
    • With the blue plastic opening tool, use the lock screen switch by the volume button as an access point to gently lift the back cover off.
    • Wedge the opening tool until you start hearing the back cover popping off the body of the device.
    • Slide the opening tool down the length of the device.
    • Once it is about half way off, you can use your thumb to pull the rest of the back cover off.
  2. Lenovo IdeaPad A1-07 Motherboard Replacement: stap 2, afbeelding 1 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement: stap 2, afbeelding 2 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Using a Phillips #000 screwdriver, remove all 18 of the 4mm screws.
    • With the blue plastic opening tool, gently wedge the tool between the screen and the gray frame until you feel resistance.
    • Do not force the frame off because you can break off the teeth securing the frame to the screen.
    • Push in the teeth with the blue plastic opening tool, towards the center of the device, and gently pull off the frame.
    • The gray frame will still be connected to the device by a pair of wires from the motherboard to the speaker.
  3. Lenovo IdeaPad A1-07 Motherboard Replacement: stap 3, afbeelding 1 van 2 Lenovo IdeaPad A1-07 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • The speaker in the grey frame is connected to the motherboard by the white plastic connector.
    • Disconnect the speaker by separating the two sides of the speaker connector.
  4. Lenovo IdeaPad A1-07 Motherboard Replacement, Battery: stap 4, afbeelding 1 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement, Battery: stap 4, afbeelding 2 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement, Battery: stap 4, afbeelding 3 van 3
    • Use a plastic opening tool to push the white battery connector out of its socket on the motherboard.
    • Lift the battery away from the device.
  5. Lenovo IdeaPad A1-07 Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement, Motherboard: stap 5, afbeelding 3 van 3
    • Remove the three, 3mm screws holding the motherboard to the screen using the PH #000 screwdriver.
    • You will have to disconnect all the connectors on the motherboard.
    • The first connector to remove is in the center of the motherboard.
    • Use the blue plastic opening tool to slide the little black retainer, relieving pressure on the brown ribbon cable.
    • Use the blue opening tool to pull the brown ribbon cable out of the connector.
  6. Lenovo IdeaPad A1-07 Motherboard Replacement: stap 6, afbeelding 1 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement: stap 6, afbeelding 2 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • On the top left of the motherboard, to the right of the back camera is another connector.
    • To disconnect, use a blue plastic opening tool to lift and pry it up.
    • Once it snaps up out of place, it has been disconnected.
  7. Lenovo IdeaPad A1-07 Motherboard Replacement: stap 7, afbeelding 1 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement: stap 7, afbeelding 2 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Using the same process as the previous connector, disconnect a similar connector just to the left of the back camera.
  8. Lenovo IdeaPad A1-07 Motherboard Replacement: stap 8, afbeelding 1 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement: stap 8, afbeelding 2 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement: stap 8, afbeelding 3 van 3
    • On the top left of the motherboard, just next to the volume button, is another connector.
    • Use a blue plastic opening tool to lift up on the black lever.
    • Once it is pushed up, the brown ribbon can be pulled out using the spudger.
  9. Lenovo IdeaPad A1-07 Motherboard Replacement: stap 9, afbeelding 1 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement: stap 9, afbeelding 2 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement: stap 9, afbeelding 3 van 3
    • The final connector is a grey cable with a gold tip called the coaxial cable.
    • To disconnect, slide the blue plastic opening tool up to the base of the tip.
    • Twist the opening tool to gently lift up the coaxial cable.
    • The coaxial cable is snapped in tightly and may take a little bit of force.
  10. Lenovo IdeaPad A1-07 Motherboard Replacement: stap 10, afbeelding 1 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement: stap 10, afbeelding 2 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • While lifting the motherboard, you need to push the connector heads down through the holes that they come through.
    • With the cameras oriented on top, there will still be one ribbon on the right of the motherboard connected to the screen.
    • Simply lift the motherboard on the left side and flip it over to the right like turning a page.
  11. Lenovo IdeaPad A1-07 Motherboard Replacement: stap 11, afbeelding 1 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement: stap 11, afbeelding 2 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Once all the connectors are pushed through, the last thing still connecting the motherboard to the screen is the motherboard battery.
    • The connector is fixed to the metal frame by adhesive.
    • Using the black spudger, gently pry up the connector by pulling at the base of the battery.
  12. Lenovo IdeaPad A1-07 Motherboard Replacement: stap 12, afbeelding 1 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement: stap 12, afbeelding 2 van 3 Lenovo IdeaPad A1-07 Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Now you will be free to detach the screen from the front cover.
    • With the device face down, you can pull up on the top left side of the metal frame while pushing out a plastic tooth using two metal spudgers.
    • Gently lift until you feel the tension of the adhesive on the right side.
    • Once you feel tension, slide a metal spudger tool down the length of the right side to remove the adhesive.
    • Be sure to move the tool straight down the side. There is a thin copper film that can be crumpled if the spudger enters from the side.
  13. Lenovo IdeaPad A1-07 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • The motherboard is soldered to the black screen frame by an orange film tab.
    • With the screen now removed, it too can be replaced.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 353
