Ga door naar hoofdinhoud
Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement, Back Cover/Midframe: stap 1, afbeelding 1 van 3 Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement, Back Cover/Midframe: stap 1, afbeelding 2 van 3 Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement, Back Cover/Midframe: stap 1, afbeelding 3 van 3
    • With the blue plastic opening tool, use the lock screen switch by the volume button as an access point to gently lift the back cover off.
    • Wedge the opening tool until you start hearing the back cover popping off the body of the device.
    • Slide the opening tool down the length of the device.
    • Once it is about half way off, you can use your thumb to pull the rest of the back cover off.
  2. Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement: stap 2, afbeelding 1 van 3 Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement: stap 2, afbeelding 2 van 3 Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement: stap 2, afbeelding 3 van 3
    • Using a Phillips #000 screwdriver, remove all 18 of the 4mm screws.
    • With the blue plastic opening tool, gently wedge the tool between the screen and the gray frame until you feel resistance.
    • Do not force the frame off because you can break off the teeth securing the frame to the screen.
    • Push in the teeth with the blue plastic opening tool, towards the center of the device, and gently pull off the frame.
    • The gray frame will still be connected to the device by a pair of wires from the motherboard to the speaker.
  3. Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement: stap 3, afbeelding 1 van 2 Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement: stap 3, afbeelding 2 van 2
    • The speaker in the grey frame is connected to the motherboard by the white plastic connector.
    • Disconnect the speaker by separating the two sides of the speaker connector.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 426
