Ga door naar hoofdinhoud
Lenovo IdeaPad 720S-13IKB GPU Fan Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad 720S-13IKB GPU Fan Replacement, Remove back cover: stap 1, afbeelding 1 van 1
    • Power off Device
    • Remove charger
    • Remove 6 T5 Screws
    • Remove 4 T5 Screws (These Screws are at an angle)
    • Remove the back cover using opening Pics. Start at the back(where the screen is)
  2. Lenovo IdeaPad 720S-13IKB GPU Fan Replacement: stap 2, afbeelding 1 van 1
    • SSD/DisplayConnector Cover
    • Battery
    • M.2 Wifi&Bluetooth
    • Speakers
    • RAM Cover
    • CPU
  3. Lenovo IdeaPad 720S-13IKB GPU Fan Replacement, Remove Battery: stap 3, afbeelding 1 van 1
    • Unplug battery
    • Remove all 3 Screws using PH1
    • Take out the battery
  4. Lenovo IdeaPad 720S-13IKB GPU Fan Replacement: stap 4, afbeelding 1 van 1
    • Fingerprint reader
    • Touchpad
  5. Lenovo IdeaPad 720S-13IKB GPU Fan Replacement, Remove Covers: stap 5, afbeelding 1 van 2 Lenovo IdeaPad 720S-13IKB GPU Fan Replacement, Remove Covers: stap 5, afbeelding 2 van 2
    • Remove Screws with PH1
    • Remove Screws with PH0
    • Remove RAM cover
    • All covers are also secured using contact clips (Picture 2). Just pull them out
  6. Lenovo IdeaPad 720S-13IKB GPU Fan Replacement: stap 6, afbeelding 1 van 1
    • DRAM (K4aag165wb MCRC)
    • Connector To Display
    • M.2 SSD
  7. Lenovo IdeaPad 720S-13IKB GPU Fan Replacement, Remove Speaker: stap 7, afbeelding 1 van 1
    • Unplug Fans
    • Disconnect Fingerprint and Touchpad
    • Take out Speakers
  8. Lenovo IdeaPad 720S-13IKB GPU Fan Replacement, Remove Motherboard: stap 8, afbeelding 1 van 2 Lenovo IdeaPad 720S-13IKB GPU Fan Replacement, Remove Motherboard: stap 8, afbeelding 2 van 2
    • Remove screws using PH0
    • Remove screws using PH1 and take m.2 parts out
    • Dissconnect cables
    • Disconnect Display Cable
    • No Idea how to connect Display Cable (Tips welcome)
    • Push Moterboard to the left and take it out.
    • At the USB-A Port is some cushion to keep the Motherboard in place.
  9. Lenovo IdeaPad 720S-13IKB GPU Fan Replacement: stap 10, afbeelding 1 van 1
    • Remove Fan Connector
    • Remove Screw using PH1
    • Take fan out
Conclusie
Hinomi
325 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 10
