Ga door naar hoofdinhoud
Lenovo IdeaPad 330S-14IKB Battery Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad 330S-14IKB Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Begin by turning your laptop upside down so that you can access the labels on the back.
  2. Lenovo IdeaPad 330S-14IKB Battery Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad 330S-14IKB Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the 10 screws from the bottom of the laptop.
    • Safely store these screws in a place where you won't lose them, such as a magnetic pad.
    • (Silver, 5.8mm Philips #0)
  3. Lenovo IdeaPad 330S-14IKB Battery Replacement: stap 3, afbeelding 1 van 1
    • Slowly and carefully remove the back panel from the laptop.
    • Be cautious and use wedges if needed to avoid damaging the panel.
  4. Lenovo IdeaPad 330S-14IKB Battery Replacement: stap 4, afbeelding 1 van 1
    • Locate the battery in the bottom left corner.
  5. Lenovo IdeaPad 330S-14IKB Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the 5 screws that secure the battery in place.
    • (Black, 3.45mm Phillips #0)
  6. Lenovo IdeaPad 330S-14IKB Battery Replacement: stap 6, afbeelding 1 van 2 Lenovo IdeaPad 330S-14IKB Battery Replacement: stap 6, afbeelding 2 van 2
    • Near the positive and negative symbols on the battery, you'll find a wire connected to the motherboard.
    • Gently unplug this wire.
  7. Lenovo IdeaPad 330S-14IKB Battery Replacement: stap 7, afbeelding 1 van 2 Lenovo IdeaPad 330S-14IKB Battery Replacement: stap 7, afbeelding 2 van 2
    • There is a wire clipped to the side of the battery next to the hard drive; unhook this wire.
    • With the wire disconnected, remove the old battery.
Conclusie
Chris
229 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 37
Altijd: 194
