Ga door naar hoofdinhoud
Lenovo IdeaPad 330S Wireless Lan Card Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing Bottom Case: stap 1, afbeelding 1 van 2 Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing Bottom Case: stap 1, afbeelding 2 van 2
    • Turn the device off.
    • Remove the 10 screws as shown in picture.
    • Using a pry tool , remove the bottom case.
  2. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Disconnecting Battery: stap 2, afbeelding 1 van 1
    • Using a spudger gently push the plastic connector to the left in order to disconnect the battery.
  3. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing guard shield: stap 3, afbeelding 1 van 1
    • Remove the three 00# screws.
    • Remove the 2.5 mm screw.
    • Gently pry the shield.
  4. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing Wireless Card: stap 4, afbeelding 1 van 1
    • Before removing the screw (marked in red circle) remove the two antenna cables using the spudger.
    • Remove the screw.
    • The wireless card will lift, remove it.
    • Install the new wireless card.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ilia Tocheny
1.616 Reputatie
9 handleidingen geschreven
2 opmerkingen
So my laptop sometimes has no bluetooth, or wifi, or both. A quick reboot fixes it, but idk if the module is actually faulty. I've opened it before, and don't want to buy a replacement chip if this one is just seated poorly. Is there a good way to check. Thanks
Calvin Mills - Antwoord
Using the correct tools try to disconnect the cables from the socket and reseat them in the socket make just do as the guide but without removing the WLAN card
Ilia Tocheny -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 48
Altijd: 3,324
