Inleiding
You may find yourself in need of additional fast storage to feed hungry computer applications such as graphics and video editing tools. If you would like to replace a faulty NVMe drive or one with insufficient capacity, follow this guide.
The battery for this device is not easily accessible and will require opening the device. Before you begin your replacement, be sure to disconnect the laptop from any power source. Additionally, we recommend that you turn off the device wait 5 minutes.
If you live in area rich of Static Electricity please advise using an ESD Strap.
Wat je nodig hebt
Turn off the device before working on it.
Remove the 10 screws as shown in the picture
Gently using the tool pry off the bottom case
Using a spudger gently push the plastic connector to the left in order to disconnect the battery.
5 andere personen hebben deze handleiding voltooid.
7 opmerkingen
Is this machine compatible with both NVMe SSD and SATA SSD on the M2 port? Thank you.
This machine is compatible NVMe and Sata drive.
mine came with m2 2242 ssd and is reaching its lifespan, can I replace it with m2 2280?
Yes you can but before you do this… make sure to backup all data before doing the upgrade. When you will install the new ssd make you sure it is Nvme gen 3 and not gen4.
Samsung 980 is recommended ssd for the upgrade…
any reason why I cannot install nvme gen4? its the same price as gen3
isnt it backwards compatible?
