Ga door naar hoofdinhoud
Lenovo IdeaPad 330S Fan and Thermal Unit
Wat je nodig hebt
  1. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing bottom case: stap 1, afbeelding 1 van 2 Lenovo IdeaPad 330S Fan and Thermal Unit, Removing bottom case: stap 1, afbeelding 2 van 2
    • Turn off the device and disconnect from the power.
    • Remove the 10 screws as shown in picture.
    • Using a plastic pry tool remove the bottom case (gently).
  2. Lenovo IdeaPad 330S Fan and Thermal Unit, Disconnecting Battery: stap 2, afbeelding 1 van 1
    • Using a spudger gently push the black connector to the left (red circle).
    • If you want to remove the battery by removing the five screws labeled in blue.
  3. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing guard shield: stap 3, afbeelding 1 van 2 Lenovo IdeaPad 330S Fan and Thermal Unit, Removing guard shield: stap 3, afbeelding 2 van 2
    • Remove the 3 screws that are circuled in blue. Then remove the red one.
    • The red circle is a M2.5 and the blue circle are M2.0 those are different screws!
    • Remove the black shield
  4. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing Cooling Fan: stap 4, afbeelding 1 van 1
    • Remove the two black screws that are marked in red
    • Disconnect the fan (blue marker) from MB by pushing gently to the left using a spudger.
  5. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing the Thermal unit: stap 5, afbeelding 1 van 1
    • Remove the 6 screws in revrse of the number stated on screws.
    • Replace the thermal paste with a fresh one
    • Removing the fan is not needed but will help with easier dissemble of thermal unit
Conclusie
3 andere personen hebben deze handleiding voltooid.
Ilia Tocheny
1.616 Reputatie
9 handleidingen geschreven
2 opmerkingen
I want to buy this piece, where can I find it for purchase?
c.lobos_7 - Antwoord
Good question, you could try at your local Lenovo Service provider.
Ilia Tocheny - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 1,596
