Ga door naar hoofdinhoud
Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Back Panel: stap 1, afbeelding 1 van 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Back Panel: stap 1, afbeelding 2 van 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Ensure the laptop is powered off.
    • Turn the device over so the bottom is facing up.
    • Remove the 13 6 mm screws from the bottom of the device using a Phillips #0 screwdriver.
    • Carefully glide a Jimmy along the seam of the casing.
    • Remove the back cover of the laptop.
  2. Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Battery: stap 2, afbeelding 1 van 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Battery: stap 2, afbeelding 2 van 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Battery: stap 2, afbeelding 3 van 3
    • Remove the three 6 mm screws from the tabs surrounding the battery using a Phillips #0 screwdriver.
    • Carefully separate the battery connector from the device using a spudger.
    • Lift the battery up and remove it from the device.
  3. Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Speaker: stap 3, afbeelding 1 van 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Speaker: stap 3, afbeelding 2 van 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Speaker: stap 3, afbeelding 3 van 3
    • Remove the connector for the speakers from the motherboard using a spudger.
    • Gently lift the speakers from the device using a spudger.
    • Carefully lift the red wire from its dock along the bottom.
    • Remove the speakers from the device.
Conclusie
Matthew Bridge
245 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-1, Konn Fall 2024 Lid van UMass Dartmouth, Team 2-1, Konn Fall 2024
UMASSD-KONN-F24S2G1
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 30
Altijd: 105
