Ga door naar hoofdinhoud
Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement, Bottom Back Cover: stap 1, afbeelding 1 van 1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: stap 2, afbeelding 2 van 2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement, Wireless LAN Card: stap 3, afbeelding 1 van 1
    • The wireless LAN card is located at the center of the laptop.
  4. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the 3mm Phillips #1 screw that holds the WLAN card in place.
  5. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the black and white cables from the WLAN card.
  6. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: stap 6, afbeelding 1 van 1
    • Gently remove the WLAN card out of its slot.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Ammar Dodin
1.057 Reputatie
6 handleidingen geschreven
UC Davis, Team 1-3, Rodger Winter 2017 Lid van UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Leden
3 opmerkingen
Thanks Ammar, I thought my wifi card was jammed until I saw your post.
Turns out one of the cables (white one) was disconnected which lead to my wifi signal being non-existent. I plugged it in again and its working properly again.
Cheers
Vlottie
David Vlotman - Antwoord
Thanks for say, white is 1
SABBIR HOSSAIN -
How to connect wire black and white to pin 1 and 2, plz help
SABBIR HOSSAIN - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 2,798
