Ga door naar hoofdinhoud
Lenovo IdeaPad 300-17ISK RAM Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad 300-17ISK RAM Replacement, Bottom Back Cover: stap 1, afbeelding 1 van 1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK RAM Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad 300-17ISK RAM Replacement: stap 2, afbeelding 2 van 2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK RAM Replacement, RAM: stap 3, afbeelding 1 van 1
    • The RAM sticks are located near the bottom of the device, and they are arranged next to each other.
  4. Lenovo IdeaPad 300-17ISK RAM Replacement: stap 4, afbeelding 1 van 3 Lenovo IdeaPad 300-17ISK RAM Replacement: stap 4, afbeelding 2 van 3 Lenovo IdeaPad 300-17ISK RAM Replacement: stap 4, afbeelding 3 van 3
    • Locate the two dislocating latches on each side of the stick and place your fingers on them.
    • Pull the tabs away from the stick simultaneously until the stick pops out of place.
    • Gently remove the RAM stick once it has popped out of its place.
    • If necessary, repeat the same process with the second RAM stick that is adjacent to the first one.
Conclusie
To reassemble the device, install your new stick(s) and follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Ammar Dodin
1.057 Reputatie
6 handleidingen geschreven
UC Davis, Team 1-3, Rodger Winter 2017 Lid van UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 29
Altijd: 2,403
