Ga door naar hoofdinhoud
Lenovo IdeaPad 300-17ISK Optical Drive Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad 300-17ISK Optical Drive Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Unscrew the three 6mm Phillips #1 screws from the upper back cover.
  2. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: stap 2, afbeelding 1 van 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: stap 2, afbeelding 2 van 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: stap 2, afbeelding 3 van 3
    • Place the opening tool's head under any edge of the keyboard.
    • Pull upwards to unsnap the keyboard.
    • Use your fingers and the opening tool to pop the keyboard out of its place.
    • You should't use any excessive force because the keyboard is still attached to the motherboard.
  3. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: stap 3, afbeelding 1 van 2 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: stap 3, afbeelding 2 van 2
    • Push the keyboard connector latch upwards with the spudger.
    • You shouldn't use excessive force. The connector latch is very fragile.
    • The keyboard connector cable should slide right out.
  4. Lenovo IdeaPad 300-17ISK Optical Drive Replacement, Optical Drive: stap 4, afbeelding 1 van 1
    • Remove the 6mm Phillips #1 screw that sits in the center of the front plate below the keyboard. This screw sits between two adjacent tabbed holes.
  5. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: stap 5, afbeelding 1 van 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: stap 5, afbeelding 2 van 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: stap 5, afbeelding 3 van 3
    • Insert the opening tool's head into one of the tabbed holes.
    • With the opening tool's head inserted under a tab, push to the right. The optical drive should slide out easily.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ammar Dodin
1.057 Reputatie
6 handleidingen geschreven
UC Davis, Team 1-3, Rodger Winter 2017 Lid van UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 34
Altijd: 5,120
