Ga door naar hoofdinhoud
Lenovo IdeaPad 300-17ISK Hard Drive Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Bottom Back Cover: stap 1, afbeelding 1 van 1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 1
    • The hard drive is located at the bottom of the laptop.
  4. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the four 6mm Phillips #1 screws that hold the hard drive frame in place.
  5. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Gently pick up the hard drive without pulling it completely out.
    • You shouldn't use excessive force because the hard drive is still attached to the motherboard.
  6. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: stap 6, afbeelding 1 van 2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Use the spudger to disconnect the hard drive from it motherboard connector.
    • The connector should come right off without excessive force.
  7. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: stap 7, afbeelding 1 van 2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: stap 7, afbeelding 2 van 2
    • Remove the four 3mm Phillips #1 screws, two on each side, that secure the hard drive in its protective frame.
    • These screws are different from the rest of the laptop screws. You can damage the drive using the wrong screws.
    • Lift the frame to separate it from the hard drive.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Ammar Dodin
1.057 Reputatie
6 handleidingen geschreven
UC Davis, Team 1-3, Rodger Winter 2017 Lid van UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Leden
3 opmerkingen
Clear and easy - thanks!
Beth Pierce - Antwoord
Very good and to the point
al_stewart - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 45
Altijd: 9,765
