Ga door naar hoofdinhoud
Lenovo IdeaPad 3-15IIL05 Back Cover Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Unfasten the back cover: stap 1, afbeelding 1 van 2 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Unfasten the back cover: stap 1, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the ten screws securing the back cover:
    • Six 7.6 mm-long screws
    • Four 4.7 mm-long screws
  2. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Insert an opening pick: stap 2, afbeelding 1 van 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Insert an opening pick: stap 2, afbeelding 2 van 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Insert an opening pick: stap 2, afbeelding 3 van 3
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
    • Insert the flat side of an opening pick between the top left corner of the back cover and frame.
    • Angle the pick down to about 45 degrees.
  3. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the left clips: stap 3, afbeelding 1 van 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the left clips: stap 3, afbeelding 2 van 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the left clips: stap 3, afbeelding 3 van 3
    • Keep the opening pick angled down at about 45 degrees while sliding it along the front and side edges to help release the clips.
    • Slide the pick to the bottom left corner of the laptop to release the left clips.
  4. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the bottom clips: stap 4, afbeelding 1 van 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the bottom clips: stap 4, afbeelding 2 van 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the bottom clips: stap 4, afbeelding 3 van 3
    • Slide the opening pick to the bottom right corner to release the bottom clips.
  5. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the right clips: stap 5, afbeelding 1 van 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the right clips: stap 5, afbeelding 2 van 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the right clips: stap 5, afbeelding 3 van 3
    • Slide the opening pick to the top right corner to release the right clips.
  6. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Insert an opening pick: stap 6, afbeelding 1 van 2 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Insert an opening pick: stap 6, afbeelding 2 van 2
    • Insert the flat end of an opening pick between the back cover and frame, to the left of the right hinge.
    • Pry the back cover up with the pick to release the top right clips.
    • Leave the pick inserted next to the right hinge.
  7. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the top clips: stap 7, afbeelding 1 van 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the top clips: stap 7, afbeelding 2 van 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the top clips: stap 7, afbeelding 3 van 3
    • Angle the pick up to about 45 degrees.
    • Slide the opening pick to the top left corner to release the remaining clips.
  8. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Remove the back cover: stap 8, afbeelding 1 van 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Remove the back cover: stap 8, afbeelding 2 van 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Remove the back cover: stap 8, afbeelding 3 van 3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
Conclusie
Spencer Day
61.610 Reputatie
445 handleidingen geschreven
iFixit Lid van iFixit
Staff
140 Leden
18.077 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 74
Afgelopen 30 dagen: 296
Altijd: 2,035
