Inleiding
Use this guide to replace the facility SSD card in your Lenovo IdeaPad 3-15ADA05. Before using this guide, be sure to review the troubleshooting page to ensure the SSD card is the problem. If the computer was recently used, give it 5 to 10 minutes to cool down.
Wat je nodig hebt
Remove the 6 M2 x 5mm screws located at the top half of the laptop using a #0 phillips head, then remove the 4 M2 x 2.5mm screws located at the bottom of the laptop using a #0 phillips head.
