Inleiding
Use this guide to replace the RAM stick in your Lenovo IdeaPad 3-15ADA05. Before using this guide, be sure to review the troubleshooting page to ensure the RAM is the problem. If the computer was recently used, give it 5 to 10 minutes to cool down.
Wat je nodig hebt
Use a Phillips #0 screwdriver to remove the six M2 x 5 mm screws located at the top half of the laptop.
Use a Phillips #0 screwdriver to remove the four M2 x 2.5 mm screws located at the bottom of the laptop.
