Inleiding
Use this guide to replace the facility fan in your Lenovo IdeaPad 3-15ADA05. Before using this guide, be sure to review the troubleshooting page to ensure the fan is the problem. If the computer was recently used, give it 5 to 10 minutes to cool down.
Wat je nodig hebt
Remove the six M2 x 5mm screws located at the top half of the laptop using a #0 Phillips head, then remove the four M2 x 2.5mm screws located at the bottom of the laptop using a #0 Phillips head.
