Ga door naar hoofdinhoud
Lenovo IdeaPad 130-15AST Speaker Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad 130-15AST Speaker Replacement, DVD/CD Optical Drive: stap 1, afbeelding 1 van 1
    • Verify that the DVD/CD Tray is free of DVD's and CD's.
    • Using a Phillips #00 screwdriver, remove one of the 6.0mm screws.
  2. Lenovo IdeaPad 130-15AST Speaker Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad 130-15AST Speaker Replacement: stap 2, afbeelding 2 van 2
    • Using the Jimmy Tool, gently pry the DVD/CD Drive away from the case of the laptop.
  3. Lenovo IdeaPad 130-15AST Speaker Replacement: stap 3, afbeelding 1 van 1
    • Gently slide the DVD/CD Drive out of the laptop.
  4. Lenovo IdeaPad 130-15AST Speaker Replacement, Battery: stap 4, afbeelding 1 van 1
    • Before proceeding, make sure the computer is turned off and it is not connected to any power source.
    • Using a Phillips #00 screwdriver, remove twelve of the 6.0mm screws.
  5. Lenovo IdeaPad 130-15AST Speaker Replacement: stap 5, afbeelding 1 van 3 Lenovo IdeaPad 130-15AST Speaker Replacement: stap 5, afbeelding 2 van 3 Lenovo IdeaPad 130-15AST Speaker Replacement: stap 5, afbeelding 3 van 3
    • Do not try to completely remove this case without ensuring the entire case is free of connection points as this could crack or damage the case.
    • Use a thin, flat edge to gently break the seal of the case.
  6. Lenovo IdeaPad 130-15AST Speaker Replacement: stap 6, afbeelding 1 van 2 Lenovo IdeaPad 130-15AST Speaker Replacement: stap 6, afbeelding 2 van 2
    • Make sure that the back panel is completely free from the laptop.
    • Grab the sides of the back panel of the laptop with two hands. Then separate the panel from the laptop by lifting up.
  7. Lenovo IdeaPad 130-15AST Speaker Replacement: stap 7, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove three 6.0mm screws.
  8. Lenovo IdeaPad 130-15AST Speaker Replacement: stap 8, afbeelding 1 van 3 Lenovo IdeaPad 130-15AST Speaker Replacement: stap 8, afbeelding 2 van 3 Lenovo IdeaPad 130-15AST Speaker Replacement: stap 8, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Using a pair of tweezers, remove the black plug which includes 8 wires.
  9. Lenovo IdeaPad 130-15AST Speaker Replacement: stap 9, afbeelding 1 van 2 Lenovo IdeaPad 130-15AST Speaker Replacement: stap 9, afbeelding 2 van 2
    • Grabbing the sides of the battery with one hand, remove the battery from the laptop.
  10. Lenovo IdeaPad 130-15AST Speaker Replacement, Speaker: stap 10, afbeelding 1 van 1
    • Using a prying tool, remove the white plug (which includes 4 different colored wires) from the motherboard. Repeat the same step for the other plug.
    • This plug is small and fragile. You should not use a lot of force to separate the plastic connection from the motherboard.
  11. Lenovo IdeaPad 130-15AST Speaker Replacement: stap 11, afbeelding 1 van 1
    • Disconnect the speaker wires from their connection tabs along the front of the computer.
    • These wires are not connected to anything internally. They connect the speakers from the power supply to each other.
  12. Lenovo IdeaPad 130-15AST Speaker Replacement: stap 12, afbeelding 1 van 2 Lenovo IdeaPad 130-15AST Speaker Replacement: stap 12, afbeelding 2 van 2
    • To remove the speakers, pinch the inside edge and lift upwards.
    • These speakers are help in by O-rings. Be sure not to lose these, as new speakers do not come with new O-rings.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 934
