Ga door naar hoofdinhoud
Lenovo IdeaPad 130-15AST Battery Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad 130-15AST Battery Replacement, DVD/CD Optical Drive: stap 1, afbeelding 1 van 1
    • Verify that the DVD/CD Tray is free of DVD's and CD's.
    • Using a Phillips #00 screwdriver, remove one of the 6.0mm screws.
  2. Lenovo IdeaPad 130-15AST Battery Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad 130-15AST Battery Replacement: stap 2, afbeelding 2 van 2
    • Using the Jimmy Tool, gently pry the DVD/CD Drive away from the case of the laptop.
  3. Lenovo IdeaPad 130-15AST Battery Replacement: stap 3, afbeelding 1 van 1
    • Gently slide the DVD/CD Drive out of the laptop.
  4. Lenovo IdeaPad 130-15AST Battery Replacement, Battery: stap 4, afbeelding 1 van 1
    • Before proceeding, make sure the computer is turned off and it is not connected to any power source.
    • Using a Phillips #00 screwdriver, remove twelve of the 6.0mm screws.
  5. Lenovo IdeaPad 130-15AST Battery Replacement: stap 5, afbeelding 1 van 3 Lenovo IdeaPad 130-15AST Battery Replacement: stap 5, afbeelding 2 van 3 Lenovo IdeaPad 130-15AST Battery Replacement: stap 5, afbeelding 3 van 3
    • Do not try to completely remove this case without ensuring the entire case is free of connection points as this could crack or damage the case.
    • Use a thin, flat edge to gently break the seal of the case.
  6. Lenovo IdeaPad 130-15AST Battery Replacement: stap 6, afbeelding 1 van 2 Lenovo IdeaPad 130-15AST Battery Replacement: stap 6, afbeelding 2 van 2
    • Make sure that the back panel is completely free from the laptop.
    • Grab the sides of the back panel of the laptop with two hands. Then separate the panel from the laptop by lifting up.
  7. Lenovo IdeaPad 130-15AST Battery Replacement: stap 7, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove three 6.0mm screws.
  8. Lenovo IdeaPad 130-15AST Battery Replacement: stap 8, afbeelding 1 van 3 Lenovo IdeaPad 130-15AST Battery Replacement: stap 8, afbeelding 2 van 3 Lenovo IdeaPad 130-15AST Battery Replacement: stap 8, afbeelding 3 van 3
    • Using a pair of tweezers, remove the black plug which includes 8 wires.
  9. Lenovo IdeaPad 130-15AST Battery Replacement: stap 9, afbeelding 1 van 2 Lenovo IdeaPad 130-15AST Battery Replacement: stap 9, afbeelding 2 van 2
    • Grabbing the sides of the battery with one hand, remove the battery from the laptop.
Conclusie
4 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 20
Altijd: 7,573
