Ga door naar hoofdinhoud
Lenovo IdeaPad 110-17IKB Screen Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad 110-17IKB Screen Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • First, before you do anything, make sure the computer has been turned off and unplugged.
    • Place the the computer bottom facing up. Unscrew the eleven 6 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad 110-17IKB Screen Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad 110-17IKB Screen Replacement: stap 2, afbeelding 2 van 2
    • Use an opening tool to gently disconnect the clips on the side of the back panel.
    • DO NOT try to force open the panel, as this may cause damage to it.
  3. Lenovo IdeaPad 110-17IKB Screen Replacement: stap 3, afbeelding 1 van 2 Lenovo IdeaPad 110-17IKB Screen Replacement: stap 3, afbeelding 2 van 2
    • Pry out the optical drive opposite of the laptop.
    • Since the screws have already been removed, you will not need to worry about any more screws on the optical drive.
  4. Lenovo IdeaPad 110-17IKB Screen Replacement: stap 4, afbeelding 1 van 3 Lenovo IdeaPad 110-17IKB Screen Replacement: stap 4, afbeelding 2 van 3 Lenovo IdeaPad 110-17IKB Screen Replacement: stap 4, afbeelding 3 van 3
    • Release the remaining clasp and remove the lower case.
  5. Lenovo IdeaPad 110-17IKB Screen Replacement, Screen: stap 5, afbeelding 1 van 3 Lenovo IdeaPad 110-17IKB Screen Replacement, Screen: stap 5, afbeelding 2 van 3 Lenovo IdeaPad 110-17IKB Screen Replacement, Screen: stap 5, afbeelding 3 van 3
    • Open the laptop, make sure it is facing you.
    • Using a opening pick, detach the clips around screen that is holding the bezels in place.
    • Remove all bezels.
  6. Lenovo IdeaPad 110-17IKB Screen Replacement: stap 6, afbeelding 1 van 3 Lenovo IdeaPad 110-17IKB Screen Replacement: stap 6, afbeelding 2 van 3 Lenovo IdeaPad 110-17IKB Screen Replacement: stap 6, afbeelding 3 van 3
    • Remove all four 3 mm screws with the a Phillips #0 screwdriver.
  7. Lenovo IdeaPad 110-17IKB Screen Replacement: stap 7, afbeelding 1 van 1
    • Carefully disconnect the cable connector from the connecting port.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cameron Mounce
668 Reputatie
5 handleidingen geschreven
Gateway, Team 1-3, Pee Fall 2023 Lid van Gateway, Team 1-3, Pee Fall 2023
GCC-PEE-F23S1G3
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 61
