Ga door naar hoofdinhoud
Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • First, before you do anything, make sure the computer has been turned off and unplugged.
    • Place the the computer bottom facing up. Unscrew the eleven 6 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: stap 2, afbeelding 2 van 2
    • Use an opening tool to gently disconnect the clips on the side of the back panel.
    • DO NOT try to force open the panel, as this may cause damage to it.
  3. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: stap 3, afbeelding 1 van 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: stap 3, afbeelding 2 van 2
    • Pry out the optical drive opposite of the laptop.
    • Since the screws have already been removed, you will not need to worry about any more screws on the optical drive.
  4. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: stap 4, afbeelding 1 van 3 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: stap 4, afbeelding 2 van 3 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: stap 4, afbeelding 3 van 3
    • Release the remaining clasp and remove the lower case.
  5. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement, Hard Disk Drive (HDD): stap 5, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to unscrew the four 5 mm screws that are holding the hard drive in place.
  6. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: stap 6, afbeelding 1 van 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: stap 6, afbeelding 2 van 2
    • Do not lift the hard drive straight up; this might break the connection port.
    • Softly slide the hard drive away from the port.
  7. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: stap 7, afbeelding 1 van 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: stap 7, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver remove the 2 screws from both sides of the hard drive (total of 4 screws).
  8. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: stap 8, afbeelding 1 van 1
    • Remove the hard drive from the housing mount.
Conclusie
Cameron Mounce
668 Reputatie
5 handleidingen geschreven
Gateway, Team 1-3, Pee Fall 2023 Lid van Gateway, Team 1-3, Pee Fall 2023
GCC-PEE-F23S1G3
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 119
