Inleiding
If the device does not load past the Lenovo loading screen, then there might be a problem with the amount of RAM or a damaged RAM. Another indicator of there being a problem with the RAM is if a RAM failure message occurs on the screen. Follow the guide to replace the RAM.
Wat je nodig hebt
Flip the IdeaPad bottom side up.
Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
Flip the computer back to top facing.
Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
Place the laptop bottom facing up.
Using a Phillips #1 screwdriver, remove the remaining eight 6.0mm screws on the back panel.
Turn the laptop upside down and gently pry the top case free from the bottom case.
On the back panel, the RAM is located at the bottom of the logic board.
Press the silver two hinges at the bottom corners of the RAM to loosen the RAM.
Remove the loosened RAM from the back panel.
5 andere personen hebben deze handleiding voltooid.
