Inleiding
If nothing occurs on the screen when you press on the keys, then the keyboard may be faulty. To replace the keyboard, follow the provided guide to fix the faulty keyboard.
  1. Use the plastic opening tool to pry the keyboard up and away from the bottom assembly.
    • Use the plastic opening tool to pry the keyboard up and away from the bottom assembly.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  3. Next disconnect the keyboard cable by using the tip of the spudger or your finger to lightly push out the ribbon from the contact port.
    • Next disconnect the keyboard cable by using the tip of the spudger or your finger to lightly push out the ribbon from the contact port.
    • Completely remove the keyboard from the bottom assembly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tyler
354 Reputatie
3 handleidingen geschreven
UW Tacoma, Team S1-G5, Rose Fall 2018 Lid van UW Tacoma, Team S1-G5, Rose Fall 2018
UWT-ROSE-F18S1G5
4 Leden
8 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 2
Afgelopen 7 Dagen: 15
Afgelopen 30 Dagen: 37
Altijd: 118
