Wat je nodig hebt
Remove the two keyboard screws on the back of the device(the two on the same row)
Insert a prying tool in the crack between the keyboard and frame. Start by the power button and go all the way round the keyboard.
After the keyboard is removed, remove the screw and the battery connector.
Remove the screw that is under the two keyboard screws and pull the disk drive out.
Flip the laptop over and in the crack between the two case pieces slide a prying tool in between and follow the perimeter until the two pieces are separated.
Remove the four screws the hold the metal cage onto the drive to separate them.
Één andere persoon heeft deze handleiding voltooid.
