Ga door naar hoofdinhoud
Lenovo IdeaPad 110-15IBR Hard Drive Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad 110-15IBR Hard Drive Replacement, keyboard: stap 1, afbeelding 1 van 2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement, keyboard: stap 1, afbeelding 2 van 2
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source. Before removing the drive, make a backup copy of all the information on it if possible. Never remove the drive while the system is operating or in suspend mode.
    • Place laptop with the bottom facing up. Using a Philip #1 screwdriver unscrew all 13 screws. Gently pry the back out using a plastic opening tool, starting from one of the corners.
  2. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #1 screwdriver, remove the four (5mm) screws holding the hard drive in place.
  3. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: stap 3, afbeelding 1 van 2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Do not lift hard drive straight up otherwise you might risk breaking the connection port.
    • Gently slide the hard drive away and out out of the connection port.
  4. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: stap 4, afbeelding 1 van 2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Using a Philip #1 screwdriver remove 2 screws from each side, (removing 4 screws in total) holding the hard drive into the housing.
  5. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Remove hard drive from housing.
Conclusie
To reassemble your device, follow these instructions in reverse order with your new replacement hard drive.
14 andere personen hebben deze handleiding voltooid.
Saddam Alsinai
669 Reputatie
4 handleidingen geschreven
UW Tacoma, Team S3-G4, Liner Fall 2017 Lid van UW Tacoma, Team S3-G4, Liner Fall 2017
UWT-LINER-F17S3G4
4 Leden
14 handleidingen geschreven
3 opmerkingen
Unplug or remove battery first?
Chris Quirke - Antwoord
you do not need to unplug or remove the battery
Holden Phillips - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 40
Altijd: 19,911
