Ga door naar hoofdinhoud
Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Remove the thirteen 6 mm Phillips #0 screws.
  2. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: stap 2, afbeelding 2 van 2
    • Use an opening tool to gently disconnect most of the clips on the back panel.
    • DO NOT force the panel out towards the optical disk drive.
  3. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: stap 3, afbeelding 1 van 3 Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: stap 3, afbeelding 2 van 3 Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: stap 3, afbeelding 3 van 3
    • Pry the disk drive away from the center of the laptop.
    • Don't worry about any screws since we already removed the screws that are associated with the drive.
    • Once the drive is removed, remove the one 2 mm Phillips #0 screw that is now exposed.
  4. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: stap 4, afbeelding 1 van 3 Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: stap 4, afbeelding 2 van 3 Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: stap 4, afbeelding 3 van 3
    • Unclip any of the remaining clips and remove the back panel.
  5. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement, Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the four 6 mm Phillips #0 mounting screws.
  6. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: stap 6, afbeelding 1 van 3 Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: stap 6, afbeelding 2 van 3 Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: stap 6, afbeelding 3 van 3
    • Detach the wire connected to the motherboard and remove the battery assembly.
  7. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement, Speaker Replacement: stap 7, afbeelding 1 van 2 Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement, Speaker Replacement: stap 7, afbeelding 2 van 2
    • Detach the speaker wire from the motherboard.
  8. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: stap 8, afbeelding 1 van 2 Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: stap 8, afbeelding 2 van 2
    • Gently pull upwards on the speaker assembly to remove it from the case.
Conclusie
Clark Beuckman
529 Reputatie
5 handleidingen geschreven
Clemson, Team 2-3, Hunter Spring 2022 Lid van Clemson, Team 2-3, Hunter Spring 2022
CLEM-HUNTER-S22S2G3
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 135
