Inleiding
This guide details the steps to remove the battery from the Lenovo IdeaPad 110 Touch-15ACL. The battery is attached by screws and fits inside a track (it can only be removed and installed from one direction) along with the wire connected to the motherboard. Exercise caution when removing the wire and avoid pulling on the wires themselves, instead—hold onto the solid portion of the wire end. Be sure to avoid puncturing the battery and other internal components as they can cause serious injury and/or health issues.
Prior to starting this repair, be sure to turn off the device and disconnect from the power adapter.
Wat je nodig hebt
