Ga door naar hoofdinhoud
Lenovo IdeaPad 100s-14IBR Speaker Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad 100s-14IBR Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR Speaker Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaPad 100s-14IBR Speaker Replacement: stap 2, afbeelding 2 van 2
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR Speaker Replacement: stap 3, afbeelding 1 van 1
    • For safety reasons, disconnect the wires connecting the battery to the motherboard with the nylon spudger.
    • Remove the six 4mm Phillips #00 screws.
    • Remove the battery using the nylon spudger.
  4. Lenovo IdeaPad 100s-14IBR Speaker Replacement: stap 4, afbeelding 1 van 2 Lenovo IdeaPad 100s-14IBR Speaker Replacement: stap 4, afbeelding 2 van 2
    • Unplug the speakers from the motherboard.
    • Remove the two 4mm PH00 screws from the metal shield on the trackpad.
    • Lift the metal shield up slightly, being very careful not to move the ribbon cables too much. Move the speaker cables out from under the shield.
  5. Lenovo IdeaPad 100s-14IBR Speaker Replacement: stap 5, afbeelding 1 van 1
    • Lift the speakers from the case being careful of the wires connecting them. Put them to the side.
Conclusie
Bin Feng
256 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 415
