Inleiding
This guide demonstrates how to remove the SSD from the Lenovo IdeaPad 100S-141BR. In cases of hard drive or SSD issues, either failure to boot or internal damage, removing the defective hardware may be necessary. The removal process is simple and requires little to no experience to complete. Before beginning the repair process, power down the device and remove any external peripherals or charging cords.
Wat je nodig hebt
Remove the eight 4mm PH00 screws.
Remove the four 2mm PH00 screws.
6 andere personen hebben deze handleiding voltooid.
3 opmerkingen
WHAT DO i REPLACE THE ssd WITH ONCE REMOVED? I WANT TO UPGRADE TO A 1TB DRIVE. WHAT DO YOU SUGGEST FOR MY LENOVO 110S-141BR LAPTOP?
I replaced with an ssd but the laptop is not recognizing it
merci beaucoup
