Wat je nodig hebt
Lay the computer down on its side as shown.
Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
With your hands remove the 14mm screw that holds the cover on the back panel.
Gently pull the flap back to expose the expansion card retaining screw.
3 andere personen hebben deze handleiding voltooid.
Één opmerking
Why is a USB 3.1 Gen 1 adapter card called TV Tuner? It is an adapter card. What you connect to it is irelevant.
