Ga door naar hoofdinhoud
Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement
Wat je nodig hebt
  1. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement, Side Panel: stap 1, afbeelding 1 van 1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: stap 2, afbeelding 1 van 1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement, USB 3.0 Expansion Card: stap 3, afbeelding 1 van 1
    • With your hands remove the 14mm screw that holds the cover on the back panel.
    • Gently pull the flap back to expose the expansion card retaining screw.
  4. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: stap 4, afbeelding 1 van 1
    • Use the Phillips #2 to remove the 8mm screw that holds the USB 3.0 Expansion Card in place.
  5. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: stap 5, afbeelding 1 van 1
    • With moderate force, pull straight up on the expansion card to remove it from the computer.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Timothy Grebe
1.634 Reputatie
9 handleidingen geschreven
Cal Poly, Team 10-39, Amido Fall 2014 Lid van Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
4 Leden
18 handleidingen geschreven
Één opmerking
Why is a USB 3.1 Gen 1 adapter card called TV Tuner? It is an adapter card. What you connect to it is irelevant.
TheLOD2010 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 1,135
