Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. Lay the computer down on its side as shown.
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Gently slide the side panel straight back and remove from the computer.
    • Gently slide the side panel straight back and remove from the computer.
  3. MacBook-reparatiesets voor batterijen
    Vanaf $69.99
    Buy Now
    Vanaf $69.99
    Buy Now
  4. With your hands remove the 14mm screw that holds the cover on the back panel.
    • With your hands remove the 14mm screw that holds the cover on the back panel.
    • Gently pull the flap back to expose the T.V. Tuner screw.
  5. Use the Phillips #2 to remove the 8mm screw that holds the T.V. Tuner in place.
    • Use the Phillips #2 to remove the 8mm screw that holds the T.V. Tuner in place.
  6. With moderate force, pull straight up on the chip to remove it from the computer.
    • With moderate force, pull straight up on the chip to remove it from the computer.
Conclusie
Timothy Grebe
1.352 Reputatie
9 handleidingen geschreven
Cal Poly, Team 10-39, Amido Fall 2014 Lid van Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
4 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 2
Altijd: 542
