Ga door naar hoofdinhoud
Lenovo IdeaCentre K410 Power Supply Unit Replacement
Wat je nodig hebt
  1. Lenovo IdeaCentre K410 Power Supply Unit Replacement, Side Panel: stap 1, afbeelding 1 van 1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 Power Supply Unit Replacement: stap 2, afbeelding 1 van 1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 Power Supply Unit Replacement, Power Supply Unit: stap 3, afbeelding 1 van 2 Lenovo IdeaCentre K410 Power Supply Unit Replacement, Power Supply Unit: stap 3, afbeelding 2 van 2
    • Unplug both sets of wires attaching the power supply unit to the motherboard.
    • The largest connection requires a significant amount of force to be removed.
  4. Lenovo IdeaCentre K410 Power Supply Unit Replacement: stap 4, afbeelding 1 van 3 Lenovo IdeaCentre K410 Power Supply Unit Replacement: stap 4, afbeelding 2 van 3 Lenovo IdeaCentre K410 Power Supply Unit Replacement: stap 4, afbeelding 3 van 3
    • Unplug all cords attached to the optical drive and hard drive.
  5. Lenovo IdeaCentre K410 Power Supply Unit Replacement: stap 5, afbeelding 1 van 1
    • Using the Phillips #2 driver, unscrew the four 8mm screws attaching the power supply unit to the outside of the computer.
  6. Lenovo IdeaCentre K410 Power Supply Unit Replacement: stap 6, afbeelding 1 van 1
    • Remove the power supply unit by pulling away from the screw side and then out.
    C'est pas très détaillé.
    Hakou - Antwoord
Conclusie
9 andere personen hebben deze handleiding voltooid.
Timothy Grebe
1.634 Reputatie
9 handleidingen geschreven
Cal Poly, Team 10-39, Amido Fall 2014 Lid van Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
4 Leden
18 handleidingen geschreven
Één opmerking
What part do I need to replace the POWER BUTTON, it's broke and have to press inside to power on?
Tracy Estes - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 33
Altijd: 4,316
