Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Wat je nodig hebt
Lay the computer down on its side as shown.
Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
With your hands remove the 14mm screw that holds the cover on the back panel.
Gently pull the flap back to expose the expansion card retaining screw.
Push down on the white clips on both sides of the memory module to release it.
Gently pull up on the memory module to remove it from the unit.
Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
Loosen the four screws that hold the heat sink in place using a Phillips #2 screwdriver.
Pull the heat sink straight up to remove it.
Remove the 2 8mm screws holding the CPU cover using a Torx #20 screwdriver.
Remove the 11 mm screw using a Torx #20 screwdriver.
Remove the cover and remove the CPU by gently pulling upward.
11 andere personen hebben deze handleiding voltooid.
