Ga door naar hoofdinhoud
Lenovo IdeaCentre K410 Heat Sink Replacement
Wat je nodig hebt
  1. Lenovo IdeaCentre K410 Heat Sink Replacement, Side Panel: stap 1, afbeelding 1 van 1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 Heat Sink Replacement: stap 2, afbeelding 1 van 1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 Heat Sink Replacement, CPU Fan: stap 3, afbeelding 1 van 1
    • Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
    • Be careful not to strip the screws.
    Fan does not need to be removed from the heat sink.
    Ken - Antwoord
  4. Lenovo IdeaCentre K410 Heat Sink Replacement: stap 4, afbeelding 1 van 1
    • Unplug the fan from the motherboard by gently pulling out the single plug. Then lift the fan up and out of the computer.
  5. Lenovo IdeaCentre K410 Heat Sink Replacement, Heat Sink: stap 5, afbeelding 1 van 1
    • Loosen the four screws that hold the heat sink in place using a Phillips #2 screwdriver.
    • The screws do not come all the way out of the heat sink
    • Pull the heat sink straight up to remove it.
    Loosen these four screws with the fan attached. Unplug the fan from the motherboard and remove the heat sink / fan as one component.
    Ken - Antwoord
Conclusie
Timothy Grebe
1.634 Reputatie
9 handleidingen geschreven
Cal Poly, Team 10-39, Amido Fall 2014 Lid van Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 753
