Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Lay the computer down on its side as shown.
Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
Gently slide the side panel straight back and remove from the computer.
Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
Unplug the fan from the motherboard by gently pulling out the single plug. Then lift the fan up and out of the computer.
