Ga door naar hoofdinhoud
Lenovo IdeaCentre K410 CPU Fan Replacement
Wat je nodig hebt
  1. Lenovo IdeaCentre K410 CPU Fan Replacement, Side Panel: stap 1, afbeelding 1 van 1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 CPU Fan Replacement: stap 2, afbeelding 1 van 1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 CPU Fan Replacement, CPU Fan: stap 3, afbeelding 1 van 1
    • Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
    • Be careful not to strip the screws.
  4. Lenovo IdeaCentre K410 CPU Fan Replacement: stap 4, afbeelding 1 van 1
    • Unplug the fan from the motherboard by gently pulling out the single plug. Then lift the fan up and out of the computer.
Conclusie
Timothy Grebe
1.634 Reputatie
9 handleidingen geschreven
Cal Poly, Team 10-39, Amido Fall 2014 Lid van Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 2,294
