Ga door naar hoofdinhoud
Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement
Wat je nodig hebt
  1. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Stand Base: stap 1, afbeelding 1 van 1
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: stap 2, afbeelding 2 van 2
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  3. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Back Cover: stap 3, afbeelding 1 van 1
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: stap 4, afbeelding 1 van 3 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: stap 4, afbeelding 2 van 3 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: stap 4, afbeelding 3 van 3
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: stap 5, afbeelding 1 van 2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: stap 5, afbeelding 2 van 2
    • Once it has been separated, lift to remove.
  6. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Arm Stand: stap 6, afbeelding 1 van 2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Arm Stand: stap 6, afbeelding 2 van 2
    • Remove the four screws that secure the arm stand.
  7. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: stap 7, afbeelding 1 van 2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: stap 7, afbeelding 2 van 2
    • Lift up to remove the arm stand.
  8. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, EMI Cover: stap 8, afbeelding 1 van 3 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, EMI Cover: stap 8, afbeelding 2 van 3 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, EMI Cover: stap 8, afbeelding 3 van 3
    • Remove the 5 screws that secure the EMI cover.
    • Remove the cover.
  9. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement, Power Switch Board: stap 9, afbeelding 1 van 1
    • Locate the power switch board and the tan colored tab on it holding the blue and white ribbon cable down.
  10. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: stap 10, afbeelding 1 van 1
    • Pull the tab towards the blue and white ribbon cable to open it. Pull the cable out of the power switch board.
  11. Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: stap 11, afbeelding 1 van 2 Lenovo IdeaCentre AIO 510S-23ISU Power Switch Board Replacement: stap 11, afbeelding 2 van 2
    • Slide the power switch cable out of its slot in the direction shown, making sure to lift up the end carefully.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jackson Blake
1.119 Reputatie
9 handleidingen geschreven
Cal Poly, Team S16-G3, Banghart Winter 2018 Lid van Cal Poly, Team S16-G3, Banghart Winter 2018
CPSU-BANGHART-W18S16G3
4 Leden
Één opmerking
Hello
I have a similar problem on a Lenovo AiO 510-22ISH, how can i check if the power button board is really broken down?
After sales service said that was the problem but how can i test it?
Thank You
Fred - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 1,382
