Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
Remove the two screws on the bottom of the computer, one on each side.
Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
Unscrew the four screws that secure the hard drive enclosure.
Unplug the SATA cable. Lift to remove the hard drive enclosure.
Unscrew the four screws that hold hard drive enclosure to the hard drive, located on the side of the enclosure.
Lift the hard drive up to remove it from the enclosure.
12 andere personen hebben deze handleiding voltooid.
5 opmerkingen
you have been busy!!!!! Noticed the solutions , etc. below and that is impressive. chaosone7 @gmail.com
It’s nice and easy to get there, unfortunately the board was fried lol.
Can I replace the hard drive with a 1TB SATA III 6Gb/s 4-bit QLC V-NAND Flash 1GB Cache 2.5" Solid State Drive - Samsung QVO
The hard drive in this should be a 2.5” drive, so the replacement you listed should work
Do you have a better suggestion
