Ga door naar hoofdinhoud
Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement
Wat je nodig hebt
  1. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Stand Base: stap 1, afbeelding 1 van 1
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: stap 2, afbeelding 1 van 2 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
    No need to remove stand. Back still comes off easily.
    Marvin - Antwoord
  3. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Back Cover: stap 3, afbeelding 1 van 1
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: stap 4, afbeelding 1 van 3 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: stap 4, afbeelding 2 van 3 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: stap 5, afbeelding 1 van 2 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Once it has been separated, lift to remove.
  6. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Hard Drive: stap 6, afbeelding 1 van 2 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Hard Drive: stap 6, afbeelding 2 van 2
    • Unscrew the four screws that secure the hard drive enclosure.
  7. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: stap 7, afbeelding 1 van 1
    • Unplug the SATA cable. Lift to remove the hard drive enclosure.
  8. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: stap 8, afbeelding 1 van 2 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: stap 8, afbeelding 2 van 2
    • Unscrew the four screws that hold hard drive enclosure to the hard drive, located on the side of the enclosure.
  9. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: stap 9, afbeelding 1 van 1
    • Lift the hard drive up to remove it from the enclosure.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Jackson Blake
1.119 Reputatie
9 handleidingen geschreven
Cal Poly, Team S16-G3, Banghart Winter 2018 Lid van Cal Poly, Team S16-G3, Banghart Winter 2018
CPSU-BANGHART-W18S16G3
4 Leden
5 opmerkingen
you have been busy!!!!! Noticed the solutions , etc. below and that is impressive. chaosone7 @gmail.com
Bobby Kincannon - Antwoord
It’s nice and easy to get there, unfortunately the board was fried lol.
Charles Allen - Antwoord
Can I replace the hard drive with a 1TB SATA III 6Gb/s 4-bit QLC V-NAND Flash 1GB Cache 2.5" Solid State Drive - Samsung QVO
Donna Briggs - Antwoord
The hard drive in this should be a 2.5” drive, so the replacement you listed should work
Jackson Blake -
Do you have a better suggestion
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 71
Altijd: 15,955
