Inleiding
The heatsink of your laptop may be faulty if you notice your fan is running more than normal, or if your laptop is getting excessively hot during normal use.
Wat je nodig hebt
Turn off the computer.
Slide the battery-lock switch on the bottom of the laptop to the unlocked position.
Remove the six 9 mm screws from the back panel with a Phillips #0 screwdriver.
Remove the back plate.
Remove three 7mm spring loaded screws using a Phillips #1 screwdriver.
Remove these two 4 mm screws using a Phillips #1 screwdriver.
