Ga door naar hoofdinhoud
Lenovo G580 Keyboard Replacement
Wat je nodig hebt
  1. Lenovo G580 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Place the laptop so the bottom is facing up.
  2. Lenovo G580 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the two M2.5x4 screws connecting the removable plate to the frame of the computer using a Phillips #00 screwdriver.
  3. Lenovo G580 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Using both hands, slide the plate off of the back of the laptop.
  4. Lenovo G580 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the three screws holding the keyboard to the laptop.
  5. Lenovo G580 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Open the lid of the laptop and locate the keyboard.
  6. Lenovo G580 Keyboard Replacement: stap 6, afbeelding 1 van 2 Lenovo G580 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Insert the plastic opening tool into the corner of the laptop between the keyboard and the side of the laptop.
    • Do not force the plastic opening tool as this will damage the laptop.
    • Slide the plastic opening tool across the keyboard towards the other corner.
  7. Lenovo G580 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Grab the keyboard at the corners and pull the keyboard off the laptop.
    • Make sure to disconnect the cord connecting the keyboard to the laptop before removing the keyboard.
Conclusie
4 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 31
Altijd: 4,164
