Ga door naar hoofdinhoud
Lenovo G580 Battery Replacement
Wat je nodig hebt
  1. Lenovo G580 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure your laptop is oriented backside facing upward as seen in the image.
    • Locate the battery lock switch.
  2. Lenovo G580 Battery Replacement: stap 2, afbeelding 1 van 2 Lenovo G580 Battery Replacement: stap 2, afbeelding 2 van 2
    • Unlock the battery by moving the switch to the right.
    • The switch is unlocked when the RED of the switch is present.
  3. Lenovo G580 Battery Replacement: stap 3, afbeelding 1 van 2 Lenovo G580 Battery Replacement: stap 3, afbeelding 2 van 2
    • Hold the release switch down.
    • At the same time, push the battery upwards to remove the battery.
    • Pulling on the battery while the battery is locked will damage the laptop. Ensure the lock is properly disengaged.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 27
Altijd: 1,739
