Ga door naar hoofdinhoud
Lenovo G575 Fan Replacement
Wat je nodig hebt
  1. Lenovo G575 Fan Replacement, Fan: stap 1, afbeelding 1 van 1
    • Use the two switches to the left of and below the battery to unlock and release the battery.
    • The switch on the left should be moved to the left to unlock, then the switch on the right will release the battery.
    • Remove the battery from the laptop by lifting it out from its bay.
  2. Lenovo G575 Fan Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the five screws from the service panel on the right side.
    • Lift up the service panel.
  3. Lenovo G575 Fan Replacement: stap 3, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the three silver screws holding the fan down.
    • Pull out the fan cable from its connector on the motherboard.
    • Lift the fan out of the case.
Conclusie
Samson Wong
103 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 14
Altijd: 870
