Ga door naar hoofdinhoud
Lenovo G50-80 80E5 Battery Replacement
  1. Lenovo G50-80 80E5 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Battery Replacement: stap 2, afbeelding 1 van 3 Lenovo G50-80 80E5 Battery Replacement: stap 2, afbeelding 2 van 3 Lenovo G50-80 80E5 Battery Replacement: stap 2, afbeelding 3 van 3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Battery Replacement: stap 3, afbeelding 1 van 3 Lenovo G50-80 80E5 Battery Replacement: stap 3, afbeelding 2 van 3 Lenovo G50-80 80E5 Battery Replacement: stap 3, afbeelding 3 van 3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Battery Replacement: stap 4, afbeelding 1 van 3 Lenovo G50-80 80E5 Battery Replacement: stap 4, afbeelding 2 van 3 Lenovo G50-80 80E5 Battery Replacement: stap 4, afbeelding 3 van 3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Abigail Hood
387 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S1-G6, Simcock Fall 2017 Lid van UMass Dartmouth, Team S1-G6, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G6
4 Leden
10 handleidingen geschreven
Één opmerking
I purchased a new battery. I think I have not put the new one correctly. It does not align right. The computer is working fine. But it does not charge until I place a couple of books under the battery case, to kind of keep it in place..
Ashish Nelson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 35
Altijd: 4,607
